Rear shock mount crossmember-How thick/location? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2007, 03:59 PM
Working on the rear suspension install on my 35 chevy master...
How largr of a crossmember should I use for the upper shock mount?
I was also thinking of mounting the shocks off of the front of the axle for more room for the swaybar. What do you think?
I am using a Ford 8.8 out of an explorer
Mark
PS One of my other cars won best dare to be different by Hot Rod!
Too bad they listed the wrong motor, it was supposed to be a SBC 302
Otherwise, can't complain!
Old 12-19-2007, 06:13 PM
Youngster's Avatar
Rear shock mount cross member
Mounting the shocks in front of the axle would work. For the cross member, I would use at least 2x2x 1/4 wall set as close as i could to the top of the side rail. A gusset to the bottom of the rail would be wise. Also sleeve the cross member for the top shock mounts and use grade 8 bolts. Mounting the shocks at a 20 degree angle in at the top.
Youngster
Old 12-19-2007, 07:08 PM
31 five window
Last journal entry: grill and rear end
Youngster is right for coil over shocks. For leaf spring rear with no coil over or air shocks they are not supporting the car only dampening the up and down motion.In this case 2" X 2" X 1/8" is all that is needed.This is what I used on my big block pro street 57 chevy and several other cars that I have built. I also agree with him on the sleeve and grade 8 bolts.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 10:03 AM
Rear tranny mount for a 350 in a S-10 Countilaw Transmission - Rearend 4 12-11-2007 01:46 PM
Rear body mount shot... what to do? dmaggard Suspension - Brakes - Steering 7 09-22-2006 09:32 PM
Rear Shock Placement, Angles ZipZ28 Suspension - Brakes - Steering 22 10-08-2005 02:52 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
