Make your own. Use 1/4" angle iron, plate, rectangular tubing or whatever structural shape that will best make the bracket you need. Then weld or bolt it to the frame and use a universal shock stud bolted to the bracket to mount the shock. Here is a photo of a stud used on motorcycles but the car version is similar in shape and function.
That's how I made the rear shock mounts for this '36 Pontiac frame. Don't have a close-up picture but as I recall. I just welded a plate of 3/16" across the frame rails and bolted the shock stud to it. Here is a bolt-on shock mount on my '53 Chevy pickup. This is factory made but the principle is the same. ![]() Here is another example posted in the Photo Album on this board by member black66. Looks like he cut it out of rectangular tubing or even bent it up from sheet metal. Be creative!
Try these guy's. That is where I got my rear suspension parts.
http://www.detroitspeed.com/ Also check out my journal, there are a few pictures of how I did it. |
try speedway they are on the web i think its speedway.com
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Thump Thump in rear end?? | HotRodMan | Suspension - Brakes - Steering | 7 | 01-24-2007 06:09 PM |
| S-10/Camaro Rear End | slaveforthewave | Transmission - Rearend | 7 | 02-20-2006 01:44 PM |
| rear shock angle | zonk | Suspension - Brakes - Steering | 8 | 04-14-2005 08:11 AM |
| 79 trans am rear discs | busterbuddie | Suspension - Brakes - Steering | 2 | 01-10-2005 06:29 PM |
