Rear shock stud angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2010, 04:25 PM
57halfton's Avatar
Heres some pics of the lower shock studs on the Moser 9 inch in my Chevelle. This angle dosen't look good to me , what do you guys think ?
Gene
ID:	46572   Click image for larger version
ID:	46573   Click image for larger version
ID:	46574   Click image for larger version
Old 07-08-2010, 05:58 PM
Poor shock alignment.
Hello Gene. Your observation backs up your concern. For whatever reason the rear lower shock stud angle is way off as you noticed. The problem of early rubber bushing failure is a warranted concern. The bushing failure will result in metal to metal contact and destroy the shock absorbers' lower eye. Was the rear end designed for your vehicles application? If not, modification to the lower stud mount is possible. As long as both shocks will clear the coil spring seats, an easy modification is to first slide the lower shocks off the stud and cut the factory welded lower stud shock mounts half way between axle housing and stud from front to rear (not all the way) just enough to allow the mounts to bend upward with pressure from a boxend wrench to achieve the correct angle (recommend using a die grinder and cut off wheel as opposed to flame cut near the fuel tank or lines). When they look right you can MIG weld the birdseye cuts and add V shaped metal to strengthen the mounts. Safety glasses and stand-by water pails are a neccesity.
Old 07-08-2010, 06:10 PM
57halfton's Avatar
Thanks Roundhouse, It's a Moser 9 inch that was built by them for my Chevelle. Everything fits great except the lower shock angle. Oh well just a little rework. Gene
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Im sure that my rear wheels angle are strange...what you think Calderone Suspension - Brakes - Steering 12 06-05-2008 12:17 PM
Rear shock mount crossmember-How thick/location? marks914 Suspension - Brakes - Steering 2 12-19-2007 06:08 PM
shock angle formula hot34coupe Suspension - Brakes - Steering 4 01-21-2007 02:23 PM
rear shock angle zonk Suspension - Brakes - Steering 8 04-14-2005 08:11 AM
