Rear Spoiler - studs pulled out - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2011, 08:47 AM
Snoopy'sVette's Avatar
I am having issues with a rear spoiler, the studs rusted out and there is a fiberglass barrier covering the bottom of the spoiler. I think I need to cut out the bottom barrier somehow get new studs put in.
This is for a 1978 Corvette
Old 10-21-2011, 10:15 AM
Last journal entry: 50 Ply wagon
Take a piece of sheetmetal about 2 inches square and get the proper sixze bolt, probably 1/4x20 and weld it to the center of the sheetmetal. Then using fiberglass resin hardener, glass it to the spots and you have new studs.
Old 10-21-2011, 11:37 AM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
What you can do is, repair the fiberglass barrier using a patch of satin coat sheet metal 'glassed on to the barrier and then "keyhole" the head of the carriage bolt to fit the corresponding holes in the trunk lid.
By 'keyholing', I mean, making a round hole the size of the carriage bolt head and then cutting a slot for the square base next to the hole to allow the carriage bolt base to lock into the slot exactly in the position over top of the corresponding hole in the trunk lid.
Old 10-21-2011, 11:55 AM
Wiki Edits: 647
An alternative would be to epoxy glue the spoiler right to the deck lid, using four of five blobs of glue right over the holes in the deck lid to seal up the existing hole and allow the glue to lock into the holes.
Old 10-21-2011, 12:00 PM
Would it matter that the body is fiberglass if I decide to epoxy it on?
Old 10-21-2011, 01:06 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
evercoat 870 bonding adhesive . polyester resin has poor adhesion to cured polyester fiberglass and will not bond to smc .
Old 10-21-2011, 01:42 PM
So I should use evercoat 870 bonding adhesive?
What is SMC
Old 10-21-2011, 02:04 PM
shine's Avatar
SPI Thug
sheet molded composite .parts of your car is smc. any repair on any vette should be done with epoxy. the 870 will bond the spoiler on permanent.
Old 10-21-2011, 02:28 PM
shine's Avatar
SPI Thug
or you can use the 870 to put a stud in .
Old 10-21-2011, 03:32 PM
Maybe I can Do both!
Old 10-22-2011, 07:05 AM
Old Fool's Avatar
It is time for you to do a little plumbing!
These are used to undermount sinks to solid countertops
Follow Shines adhesive suggestion and bond the stud to your spoiler .
Now you are back in business quick and easy.
Rear Spoiler Sigmavsop Body - Exterior 1 11-22-2006 07:20 PM
78 Camaro rear spoiler? hcker2000 Body - Exterior 8 06-23-2005 02:36 PM
Rear Spoiler Hoyt Body - Exterior 2 01-16-2004 04:39 AM
77-78 rear spoiler xxx(madmax )xxx Body - Exterior 1 04-26-2003 01:49 PM
77 Camaro rear spoiler redcamaro4spd Body - Exterior 4 03-28-2003 06:17 PM
