rear step up on modela frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2010, 10:44 PM
ok here it is i want to start setting up my frame. i will use a buggy spring, and i'm making some kind of rear bones. the sedan body i have is in pieces right now and in missing the cowl. so i want to set the frame up with out the body. i am planning to channel the body just enuff to cover the frame maybe an inch or so less, so i think i can set up ride hight with out the body. i want to know how much of a kick up in the rear is a good normal amount with a stock rear cross member. and also how far back to start the kick up. thank you!
1949 Dodge five window truck frame swap TreeTop Hotrodding Basics 14 10-28-2010 12:07 PM
Rear Frame Rails on a 66 Mustang Coupe mustangsal Body - Exterior 3 08-25-2010 12:29 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Rear Axle @ Frame farmall_560 Transmission - Rearend 2 10-17-2007 10:44 PM
66 malibu rear frame replacement mlaudon General Rodding Tech 3 01-05-2006 05:19 PM
