rear suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2008, 06:02 PM
rear suspension
hey guys i need some help.i have a 54 4 door chevy and i put a coil spring rear end out of a camaro in it. but i cant get low as i would like.the coils sit on top and i cut a few rounds off but still not low enough.could i just run a set of coil over shocks and not the coils and be ok.post any ideas.thanks chris
Old 06-23-2008, 07:55 PM
powerrodsmike's Avatar
Wiki Edits: 161
Replace the coil springs with a set of airbags.
They are simple to install in a car originally equipped with coils.
Coilovers will be more work to install, as you will need to fab up mounts.
later, mikey
BE different....ACT normal.
independent rear suspension truckboy Suspension - Brakes - Steering 6 05-25-2006 11:33 AM
Rear suspension swap question. almega Suspension - Brakes - Steering 1 06-05-2005 09:52 AM
odd rear suspension problem william27103 Suspension - Brakes - Steering 1 10-18-2004 03:53 PM
rear suspension upgrade tuske427 Suspension - Brakes - Steering 4 08-07-2004 12:38 PM
rear suspension upgrade tuske427 Suspension - Brakes - Steering 0 08-05-2004 01:46 PM
