Originally Posted by ADNDIR
I Would Like To Know If 4-10 Gears Is A Good 1/4 Gear For What Type Of Motor I Have And The Weight Of A 76nova. I Cut Some Weight Out Of It.
Depends on how much power you are making and what the rear tire diameter is, and what is the maximum rpm you are looking to cross the finish line at??
What does the car actually weigh now?? What rear axle is in it now??
If by traction bars you mean slapper bars, they ain't gonna cut it. Not even on the same planet with CalTracs or similar types. A good adjustable shock (Single action or Double action) really helps too.
You may also find that once you get it hooked, that the posi unit will "hunt", sending more power to one tire then the other, trying to decide which tire has the most traction. The result is a car that wanders around badly under power. You are in spool or locker territory. Also hope you have better than just stock axles and posi unit with the kind of power your engine can make.
I know you don't want to hear it, but street racing is stupid and punk and could get somebody hurt. Take it to a track and do it right, it is easier to get things adjusted right when the surface is prepared and you have a timeslip to tell you where the car is weak or strong in the 1/4 mile. You can always do it on a No Time night, or request on a regular T-n-T night that your time doesn't get displayed or announced (N T in big shoe polish letters)
