-   -   Rear suspension on 1970 Chevelle (http://www.hotrodders.com/forum/rear-suspension-1970-chevelle-224012.html)
Lovemius 09-14-2012 07:19 PM
My 1970 Chevelle Malibu sits kind of low in the back. Just had the shocks replaced and I thought that would raise it a bit. Do I need to replace the springs to lift it up or use coiledover shocks? Please advise.
Grease_Fever 09-14-2012 08:34 PM
Dude, your shocks don't affect ride height.
Stand back and take a look at your car. Should you lower the front springs or increase the rear? That's your decision.
I have a 1968 Pontiac Tempest. I have the same situation. But, I have determined that my front end needs to be lowered. Google vehicle aerodynamics to help you decide what works best for you.
RWENUTS 09-14-2012 09:26 PM
Like Grease says. Lower the front or use some coil spring boosters in the back. Like these.
Mr. Gasket 1285 Mr. Gasket Rubber Coil Spring Spacers
