Rear suspension on 1970 Chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2012, 07:19 PM
My 1970 Chevelle Malibu sits kind of low in the back. Just had the shocks replaced and I thought that would raise it a bit. Do I need to replace the springs to lift it up or use coiledover shocks? Please advise.
Old 09-14-2012, 08:34 PM
Grease_Fever's Avatar
68 Pontrolet
Dude, your shocks don't affect ride height.
Stand back and take a look at your car. Should you lower the front springs or increase the rear? That's your decision.
I have a 1968 Pontiac Tempest. I have the same situation. But, I have determined that my front end needs to be lowered. Google vehicle aerodynamics to help you decide what works best for you.
Old 09-14-2012, 09:26 PM
RWENUTS's Avatar
Like Grease says. Lower the front or use some coil spring boosters in the back. Like these.
Mr. Gasket 1285 Mr. Gasket Rubber Coil Spring Spacers
1970 chevelle 70chevelle@live.com Introduce Yourself 1 07-24-2008 07:32 PM
1970 chevelle krullbeast Hotrodding Basics 7 06-28-2008 11:15 AM
s.o.s. need to raise rear end 1970 chevelle eklyprod Suspension - Brakes - Steering 3 12-29-2002 04:06 AM
rear coil over suspension for 70 chevelle? trav 70 Suspension - Brakes - Steering 1 12-21-2002 03:46 AM
66 Chevelle Rear Suspension Stan Roberts Transmission - Rearend 1 10-31-2002 09:08 PM
