Rear Suspension Bind - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2002, 05:49 PM
Question Rear Suspension Bind
This is a general question based on what I think I'm seeing in some solid axle rear suspension photos in various magazines. Setups using the four bar configuration usually include some means of lateral stabilization like a panard bar. Presumably, with each of the four bars being parallel to each other and a long panard parallel to the axle, vertical suspension travel is not sufficient to produce appreciable side-to-side motion as the panard swings through its arc. However, I've seen a few layouts depicted where lateral stabilization is accomplished by bars that run from the frame a couple of feet ahead of the rear axle to the differential housing. While the front pivots on the inside of the frame are proximate to the front four bar pivots, the rear pivots on the differential are well away from the rear four bar pivots. This achieves the triangulation needed to keep the axle centered, but creates separate and conflicting arcs for the lateral stabilizers and the four bars. Unless the pivots are rubber mounted, it seems like binding would occur as the suspension moves. Granted the binding would be slight and ball ends would further reduce the problem, but why design in this kind of an inherent geometric conflict into a labor of love? What am I missing?
Old 04-27-2002, 07:52 PM
4 Jaw Chuck's Avatar
Post
This design is used to put the rear axle thrust vector ahead or at the the vehicles roll center, in essence it prevents the squat you see when a car launches. You can even design in rear axle rise under power if you desired. This of course is very popular with off road racers for these reasons. The Heim joints allow free movement and eliminate binding. There's a photo at the bottom of this page that shows the best setup and it eliminates the panhard rod while keeping the axle centered.
<a href="http://www.truckworld.com/4x4-OffRoad/00-herbstf-2504x4/herbstf-250-p2.html" target="_blank">http://www.truckworld.com/4x4-OffRoad/00-herbstf-2504x4/herbstf-250-p2.html</a>
— Han Solo
Old 05-07-2002, 11:28 PM
Post
Thanks for the feedback. Your vector comments shed light on the why, but I'm still perplexed by the how. The picture you provided is what I was talking about. Heim joints would eliminate twisting of the stabilizers, but wouldn't seem to allow the length variation you need to avoid binding due to the different arcs swung by the stabilizers and other links parallel to the frame. Do you know if some sort of rubber mounting was used on either end of any of the stabilizers/suspension rods?
Old 05-08-2002, 10:08 AM
Cool
suspension components that use a heim joint typically have one on each end to limit axle wrap. The trade off is the suspension will be a little rougher than a rubber or urithane bushed suspension. Most rodders are willing to make the tradeoff of cumfort for performance. I have seen many streat driven drag cars with heim joint bushed rear ends and they work well. It will produce a solid rear end that will hook up well at the track.
Old 05-08-2002, 11:29 AM
Post
In essence DR the different lengths will rotate the axle housing which can be used to keep the universal joint aligned through the very long travel these types of suspension designs are subject to. You could compare it to a front suspension that has unequal length control arms that in effect gives more positive camber through it's travel. Of course this can be excessive and detrimental depending on the design, length of arm, position of pivots etc. You can take some paper cutouts and use pins as pivots to see the changes that occur during stroking of the suspension. In most cases universal joints will have a 30 degree range of acceptable motion beyond which the joint can lock and fail, best practice dictates a 15 degree range of motion to minimize wear and stress depending on load.
— Han Solo
