Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear suspension change needed?
Old 09-20-2006, 09:34 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Deuce is right, I would add that your current setup lends itself to easy spring changes so you can get your ride height and spring rate changed to suit your needs Also, a set of air bags will be really easy to install on that setup.
As far as a harsh ride is concerned: Folks will lower a car by using up all of the suspension travel, then try to keep it from bottoming out the frame on the axle by putting stiffer springs. Bad idea.
You can C- notch that frame some to get some of your clearance back. A spring relocation would help also.
I would think that the front suspension is going to be more of a challenge. What does it look like?
later, mikey
BE different....ACT normal.
