Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear suspension change needed?
Old 09-22-2006, 01:45 PM
grouch's Avatar
grouch grouch is offline
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Thanks OneMoreTime. Attached image shows both ends Z'ed. The rear looks fairly simple: A bit of jigging to hold everything in place, cut, re-weld, remove jig. The front is complicated by the extra frame rails, the coil spring hats incorporated into the crossmember, and the anti-sway bar mounts.
