Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear suspension change needed?
Old 09-22-2006, 02:23 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
On the front if you stay just behind the crossmember,,kinda like doing a clip then it can save a bunch of work..
Of course on the front you will lose some height in there so you will need to remodle the radiator support and inner fender wells to accomodate the modification...You may need to do something different on the radiator as well...
Good luck..
Sam
