rear suspension in a model a - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2013, 01:02 PM
NoobRodder's Avatar
Last journal entry: Cragars
What would give the better ride buggy spring with shocks or coil overs ? Also would panhard bar be required with both types ?
Old 03-31-2013, 01:22 PM
BigMo's Avatar
If you are using coil overs, then you will need some type of locator. Four links and ladder bars normally require a panhard to keep the axle centered under the car, a leaf spring type suspension normally does not need this centering device. A Watts linkage can also be used, but its usually too much hardware to fit under a small coupe, another alternative is a a wishbone type locator or a diagonal link bar......
The Following User Says Thank You to BigMo For This Useful Post:
NoobRodder (03-31-2013)
Old 03-31-2013, 01:43 PM
model a
Well...dont know that i can add anymore to what BigMo just posted. Thats pretty much everything in a nutshell. Depends on how radical a build you're doing. The "buggy" spring worked fine on our 32...but it also was all stock! Great little 30 hp flat 4. RAW POWER!
The Following User Says Thank You to snakebit68 For This Useful Post:
Old 03-31-2013, 03:14 PM
BigMo's Avatar
Aa
I think I have a couple pics of the panhard in my 30 Ford w a 9" and QA1 coil overs.....i will post later if i can find them
Old 03-31-2013, 04:02 PM
Irelands child's Avatar
This is a TCI Model A chassis with coil overs (plus the frasmework for a '32 gas tank. It rides and handles a heluva lot better then the buggy spring rear end:
Then under the finished and many mile driven car:
If I was to build it today, would have opted for the triangulated suspension rather then the 4 bar - but that's what comes when you learn more
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
Broken 4-bar rear suspension 1930 model a,help SPRING66 Suspension - Brakes - Steering 14 03-31-2010 07:40 AM
suggestions 1930 model A front and rear suspension dustinleavitt Suspension - Brakes - Steering 7 06-16-2009 09:30 AM
model a suspension msherrow Suspension - Brakes - Steering 2 01-25-2007 08:51 AM
suspension for a model hot_rod_kid Suspension - Brakes - Steering 1 07-18-2002 02:03 PM
Model A Suspension autorat_02 Suspension - Brakes - Steering 3 06-19-2002 06:37 PM
