Rear Suspension Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2005, 06:32 PM
I have a 28 Ford coupe with the transverse leaf spring in the rear. It rides really hard. Anyone know how to soften the ride without spending a bunch of cash? I plan on buying a new chassis in a few years so I don't want to spend a lot now if I can help it.
Old 02-20-2005, 06:38 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
springs
If you have stacked springs. Just remove the smallest one.
Old 02-20-2005, 07:42 PM
BOBCRMAN@aol.com's Avatar
Start by removing the third and fifth spring from above the main leaf. I have found that if you take the second spring (above the main leaf) it will overload the main. If you need more out, take the upper ones and make a spacer to replace the lost height.
Old 02-26-2005, 06:20 PM
This is a lot of work, but get a bunch of the late model teflon slider pads that fit on the ends of each individual leaf. When you have your spring apart for leaf removal, drill a hole in each end of each leaf and install the sliders. This lets the spring work with ease and will make a big difference. Hope your shocks are good.
Trees
40 Chev front and rear suspension swap Tim240Z Suspension - Brakes - Steering 2 06-21-2004 11:01 PM
73 Camaro Rear Leaf Spring Replacment Problems mile-hightoyz Suspension - Brakes - Steering 1 05-14-2004 08:55 PM
Rear disk break problems on camaro Chevy Thunder2 Suspension - Brakes - Steering 5 04-28-2004 10:48 PM
Rear suspension ?? 41 Buick Jackyl Suspension - Brakes - Steering 0 03-07-2004 09:36 AM
66 Chevelle Rear Suspension Stan Roberts Transmission - Rearend 1 10-31-2002 09:08 PM
