Rear suspention - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2006, 01:49 AM
Rear suspention
i would like some advice in what to look for when installing a jaguar xj6 rear suspension on a home build chassis,and if any one can help me with some drawings on chassis building
Old 05-03-2006, 06:28 AM
Crosley's Avatar
Wiki Edits: 1659
moving to suspension section.
thanks.
Old 05-03-2006, 09:27 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Rear suspention
Try using the search engine for questions like this. You will get some answers very quick and not have to wait around for someone to answer. Here is what I found by typing "jaguar xj6 rear suspension" in the search engine on this site:
Jaguar Rear End
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Rear End ID Riverman Transmission - Rearend 1 08-01-2005 07:21 AM
63 biscayne rear differential problems biscuit63 Transmission - Rearend 8 07-29-2005 04:37 PM
