Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear sway bar on 70 camaro
Old 01-14-2003, 12:24 PM
BruceZ28 BruceZ28 is offline
Post Rear sway bar on 70 camaro
I have a '70 camaro that has a rear sway bar issue.It was not setup for one so I drilled the frame rails to accomadate the mounting bolts.The only problem is they have a tendancy to pull out over uneven surfaces,like pulling in and out of the driveway.Is ther a way to go in from the top so I can install nuts and lockwashers, or should I just have the shackles welded to the frame?Thanks for any help.
