Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear sway bar on 70 camaro
Old 01-14-2003, 02:16 PM
aka Duke of URL
What did you secure the mount straps to the rial with...sheet metal screws?
You will most likely have to drill an access hole on the rail sides so that you can insert locking hardware. Use at least Grade 5 and Loctite on the fasteners.
