Rear sway bar for 73-87 chevy truck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2011, 12:01 AM
Were there ever any factory installed sway bars on the 73 - 87 Chevy trucks? I am looking for one for my 79 2wd but dont really want to spend 200+ for an aftermarket one.
I was thinking that my old 89 suburban had one but I dont remember. If so, i could find one of those and use it probably. The suburbans kept the old 73-87 body style until 91 so the frame and axles should all be the same.
Old 03-04-2011, 05:40 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I believe it was an option on the Camper Specials only
So you would be limited to looking at 3/4 - 1-ton trucks
Old 03-04-2011, 05:17 PM
Wiki Edits: 31
blazers and Suburbans often had them. but IDK if that would be the same as the trucks
Old 03-04-2011, 07:34 PM
Blazers,Burbs,Box trucks, 3/4s and tons not sure if any half tons had them,but the parts swap over from what I've read.
Shane
Old 03-05-2011, 12:01 AM
Good to know they exist on things other than the later model subs. I have had and been under many 73-87 pickups and 73-91 subs (all of them 1/2 ton tho) and the only one to have a rear sway bar was the 89 sub. I have a 78 C-10 sub "trailering special" and it didn't have a rear sway bar. A guy I do some work for has a 77 C-10 and it doesn't have a rear sway bar either. I'm thinking maybe a
The rear end under my C10 is from an 86 C20 and that truck did not have a rear sway bar either. I guess I will have to dig around and see what I can find. It sure would be nice to have tho, I cant take a turn of any type like I can in my '96 2500 Suburban. Pretty sad that a big SUV can corner better than a pickup... lol.
1959 Chevy Apache Truck Original Sway Bar redsmokedotweld Suspension - Brakes - Steering 8 06-15-2011 12:17 PM
'67 Chevy Rear Sway Bar MI2600 Suspension - Brakes - Steering 4 01-16-2007 09:22 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
1959 GMC Truck Sway and rocks tom moore Suspension - Brakes - Steering 4 07-08-2005 03:29 PM
67ssdiagram showing how the rear sway bar and control arms connect to frame and rear DeathByGreaser Transmission - Rearend 0 02-08-2003 08:10 PM
