rear swaybar 49 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2006, 09:52 AM
any ideas on adding a rear heavy duty sway bar to my 49 street rod? Or panhard bar? I am using a 77 maverick 8" axle housing & stock leaf springs. I have a front sway bar but still too much body roll.
Old 12-26-2006, 10:08 AM
What are the details on your suspension? Spring rates, bar size, shocks, etc.
Old 12-26-2006, 10:09 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Other than they need to be "balanced" that is the proper sizes to work right.. if getting the sway bars from a wrecking yard I would look for car that has them on both ends..the front is generally stiffer than the rear bar as this helps to contorl the oversteer/understeer character of the car..
to get around this we make the rears adjustable in stiffness by varying the "arm length" of the rear sway bar..
Good idea to do it..the results depend on execution..
Sam
Old 12-26-2006, 10:21 AM
rear sway bar
rear leaf springs are stock re-arced 2" wide ,don't know spring rate, & am using monroe air shocks .Currently not using the Jamco kit.Exhaust pipes not used as I have corvette side pipes
Old 12-26-2006, 10:47 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Did you have to move the spring pads or is the spring spacing on the 49 the same as all other leaf spring Ford cars (except the 62-65 Fairlane, of course)???
Also how does the wheel flange to wheel flange width compare?
I have never done a 49-51.
thanks
Old 12-26-2006, 11:15 AM
rear sway bar
flange-to -flange distance is 57" & and I moved perch 1/2" in on both sides. This made perfect tire fit possable.
Old 12-26-2006, 11:20 AM
rear sway bar 49 ford tudor.
By the way, I have a Fat man rack & pinion power steering kit installed also.Greatly improved the handling. Also used there front disc brake kit.
Old 12-26-2006, 12:08 PM
30desoto's Avatar
Dodge ain't all bad
buckhorn
I used a jeep sway bar kit, it is one inch and came with different lengths for the attachment bolts, it was a complete kit from JC Whitney, just had to weld on the mount pads to the frame, and u-bolt attchment to the rearend. simple,cheap, easy and quick.
30dee
Old 12-26-2006, 02:49 PM
I have used a rear sway bar off a 89 Camaro on a 37 Chevy and I am currently running a front sway bar off a Mustang II in the rear of my 38. With both sway bars I had to pull the ends in to get them inside the frame rails, more so with the Mustang II. I gotta believe these could work in your frame as well. I used aftermarket links/bushings from AutoZone for the end mounts.
Old 12-26-2006, 05:57 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Also, a Panhard is not necessary with leaf springs.
Old 12-30-2006, 12:46 PM
xntrik's Avatar
cool thanks
So the Maverick rear end is 1/2 inch wider than the original??
So the original is 57". I keep hearing that Mavericks are 56 wide but I have only measured 2 and they were 57 1/2 same as Granada/ Mustang.
Thanks, x
Old 12-30-2006, 06:04 PM
Buckhorn, you may want to talk to Chassis Engineering. They make several different rear sway bar kits for specific vehicles and an all purpose kit. They should be able to advise you and in the past, they have told me "No, ours will not work for you".
Trees
Old 05-25-2011, 02:11 PM
bsa_bob's Avatar
So i gather that you heated the ends to pull them in??I'm trying to find a way to alter a bar, this is why i asked? if you can do that, that is step in the right direction for any who have this problem. thanks for the quick thoughts bob s
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
Ford Rear Discs, revisited. DONE! Psquare75 Suspension - Brakes - Steering 39 07-18-2006 06:10 PM
1946 ford Truck Rear End HELP Jim1926 Transmission - Rearend 1 11-29-2005 02:50 PM
'39 Ford rear parallel leafs sandman351 Suspension - Brakes - Steering 2 05-13-2004 07:38 PM
ford 9" rear beetle9 Transmission - Rearend 12 10-27-2002 05:57 AM
