Rear Swaybars? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2008, 12:48 AM
Rear Swaybars?
I am building a 1967 Holden (australian) with a 480hp sbc in it. The car should weigh in around the 3000lb mark at a guess. The rear end is still leaf spring with the addition of a watts linkage an some caltrac bars. The front end is also reasonable stock except for strengthened lower swing arms, lowered coils, power steering rack & pinion, alloy hubs and a 7/8" sway bar. I have got a 5/8" sway bar for the back but am not sure whether or not it needs it. Will it help handling or just make the rear end want to let go more often? The rear tyres are 285/35/18s if that makes any difference.
Old 09-04-2008, 02:38 AM
Adding the rear anti-roll bar will increase traction in a straight line and reduce rear traction in corners. Most cars however understeer quite a bit so putting it in should just make it more neutral.
Old 09-04-2008, 07:39 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
If you add the bar and have a limited slip/posi/locker, it will want to step out(oversteer) more on the curves under power. But, you are running 285 width tires that should get a pretty good bite.
Throttle induced oversteer can be fun.
Old 09-04-2008, 08:49 AM
daoldbuick's Avatar
Would you please explain that a little To my thinking it would seem the opposite would be true. An anti-roll bar would hold the car flatter in the corners thus limiting the wait transfer to the outside tires. and do nothing on the straight line but possibly give you a stiffer ride in bumps.
Old 09-04-2008, 09:17 AM
Tires are load sensitive. That is the more load on a tire the less the increase in traction. Because of that the "axle" with a more equal load on the tires will have more traction. Stiffer springs or anti-roll bars will cause more roll stiffness which will cause cause more load transfer from the inside tire to the outside on that pair of tires.
need basic rear end info. oldguy829 Transmission - Rearend 6 04-16-2008 04:28 PM
1964 Impala SS Hood Adjustment 64Joker Body - Exterior 4 04-13-2008 10:11 PM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 09:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
