Rear tire size for fenderless hot rod. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2006, 09:16 PM
Last journal entry: another side shot
Hi everybody. I am in the mock up stages for a building a low buck fenderless hot rod. A 1952 Mercedes Benz hot rod. I mocked up a set of big and littles. The rear wheels are 15" x 10", the rear tire has an overall diameter of 27". I need a larger diameter tire to fill the rear wheel wells, something in the low 30's. What do people usually run? How do I size atire to my rear rim> Thanks Jimmy R
Old 11-13-2006, 09:45 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Try this site out to calculate the tire size you will need.
http://www.tirerack.com/tires/tirete....jsp?techid=46
stroke to rod ratio jacobm99 Engine 17 09-16-2010 10:06 AM
So What is A Hotrod Ratchet Hotrodders' Lounge 63 10-05-2006 01:11 PM
68 Camaro - Rear Tire Size? joe brienza Engine 3 06-30-2005 11:35 AM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
Hot Rod of the Week suggestions? Jon Hotrodders' Lounge 4 06-02-2003 04:02 PM
