Rear tire size question?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2009, 11:16 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hey All.
The Gremmies gone, but I wanna start a rat rod build. I can either tub it or put more normal tires on the rear.
I was thinkin id like to set the body low and put a set of TALL rear tires on it. Something like a front semi tire. I can maybe have adaptors for a 10 lug semi tire made, but was wondering wats the tallest tire n rim I can use thats a 5 lug pattern like a forf 9 inch rear?
I dont want a 15 inch wide 44 inch mudder, but something thats tall like a 38-44 inch tall tire or a 11R22.5 inch front semi tire thats narrow (8-10 inches wide) and tall.
Any ideas or suggestions? Tnx, HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 10-31-2009, 03:33 AM
techinspector1's Avatar
Wiki Edits: 326
Intriguing idea. Here's some info I stumbled across....
http://www.tejascoach.com/tires.html
I can visualize a rear (nice deep dish) painted steel wheel, 10.00/20, with adapters cut from 3/4" aluminum plate or a set of 11.00/22.5's, done same way.
Old 11-02-2009, 12:01 PM
bullheimer's Avatar
NEVER use credit cards!
leave it to you hemmie!
i would stick with a regular wheel and and old fashioned cheater slick. they are tall as hell. unfortunately, no tread.
or: hot rod of the year:
at hotrod.com
Tire size calculator tfeverfred Suspension - Brakes - Steering 2 05-09-2007 11:04 AM
rear tire size on elky elcaminodragster General Rodding Tech 0 04-07-2007 03:21 PM
wHAT SIZE TIRE AND WHEEL WILL FIT UNDER THE REAR OF MY STOCK SUSPENSION 55 CHEVY SEDA POP BOND Suspension - Brakes - Steering 1 02-25-2007 10:56 AM
tire size for 65 malibu Haulin327 General Rodding Tech 2 04-04-2006 04:35 PM
tire size and gear ratio inquiring_mind2 Transmission - Rearend 12 08-17-2005 10:57 AM
