Rear trunk latch quit on my 2003 Trailblazer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2012, 09:26 PM
Help,
The rear electrical trunk latch stopped working. I did not see a dedicated fuse in the manual. If I hook a VOM to the elec. contacts and press the unlock keypad and get a voltage spike it would mean that the selenoid is bad. If no voltage the wires are bad. Correct?
Old 09-20-2012, 06:12 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
not that simple
This is general response not specific to that model.
If you get a 12 volt pulse at the wiring connector at the solenoid it is likely the solenoid is bad. Verify this by connecting an ohmmeter to the solenoid. If you get no reading through the solenoid (coil) that would confirm a bad solenoid.
If you do not get a 12 volt pulse at the solenoid wire connector there are a number of things that could be wrong.
This is likely a computer controlled device that is disabled under certain conditions. For example: car in gear, trunk lid open (bad switch) or security system activated etc.
The circuit is fused and could be combined with some other devices like power door locks.Testing the fuses requires a test light or meter. A shop manual will help.
ALLDATAdiy.com Leading Source of Factory Automotive Repair Information
Wires very rarely go bad but the connections do.
vicrod
Old 09-20-2012, 07:38 PM
EOD Guy's Avatar
You can verify the soleniod is good/bad by using a couple of jumper wires and testing it that way. If the soleniod is good, check the connector for 12v, if that is a no-go, check the wires where they bend at the hinge end (inside the rubber boot) and work your way back to the switch...... as Vic suggested the fuse is the 1st place to start, and it's prob tied in with the pwr door locks etc.....
Spark Plugs on my 2003 Trailblazer Meatballs Hotrodding Basics 1 09-16-2012 05:22 PM
Pull down trunk latch freedom53 Electrical 7 01-16-2008 04:29 PM
Pull Down Trunk Latch gow589 Electrical 7 08-30-2006 11:10 AM
engine flood issue 2003 trailblazer tsw5013 Engine 1 03-02-2006 09:59 AM
2003 trailblazer engine bigging down at excel tsw5013 Engine 0 03-02-2006 05:58 AM
