Which rear to use?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2010, 03:10 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Which rear to use??
Hello.
Well after the Gremlin sale I decided to build a rat rod outta an old 54 international harvester 1 ton dually model R-120 truck.
Its gonna get dual 22.5 inch semi rims and tires on the rear(yes nuts) but thats what Im after.
Question is this? Should I use the rear from the 54 IH or use a 14 bolt from a 90's dually?
Both ate heavy duty and I know the IH rear has axles n lugs the size of yer wrist, but will it handle the load? Anyone else have any issues with an IH rear? Tnx, HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 01-04-2010, 04:35 PM
big gear head's Avatar
High Performance Rear Ends
The IH rear end is probably a Dana 60 or 70. Parts are available for this rear end. The GM 10.5 14 bolt rear end might be a little stronger. Either one should work fine.
need basic rear end info. oldguy829 Transmission - Rearend 6 04-16-2008 03:28 PM
1964 Impala SS Hood Adjustment 64Joker Body - Exterior 4 04-13-2008 09:11 PM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
