rear veiw mirror too low ! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2011, 12:13 PM
On my '69 Olds Cutlass convertable, the rear veiw mirror is mounted on the upper windsheild frame and extends down 5'', right in the line of vision. It create a major 'blind spot' ! I understand all "A" bodys from 60 to 72 are this way. I asked this on another froum and 'they' also have had near misses with aothe vehicles cause of this "blind spot'' . I'm wondering (hoping) , if anyone has done anything about this, or, has any suggestions ?..........thanks
Old 08-28-2011, 01:23 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You will probably have to change to a different design to solve your problem. JMO
Cole
Old 08-28-2011, 02:58 PM
cal1320's Avatar
Jeeps have the same problem. I rotated my mirror 180 degrees. The mirror will be 2-3'' higher do to the attachment point now being on the bottom rather than the top. It may be enough of a difference to help.
Old 08-28-2011, 03:42 PM
i remember in my 70' 4 door cutlass i had the same issue, i did the same as cal suggest, never had a problem again
Old 08-28-2011, 04:51 PM
never thought of that , thanks
Old 08-28-2011, 05:08 PM
eloc431962's Avatar
Wiki Edits: 37
Me either and i will remember it also just for safe keeping.
Cole
1984 Corvette Rear Mirror 1961_MGA General Rodding Tech 1 04-02-2008 09:28 PM
rear view mirror waterman Body - Exterior 2 10-26-2006 02:29 PM
Relocate rear view mirror lluciano77 Interior 4 07-03-2005 07:09 PM
lighted rear view mirror wheel-7 Electrical 21 08-15-2003 07:21 PM
Rear Veiw Mirror causing big blind spot Jag Daddy Interior 1 07-08-2003 04:52 AM
