Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear wider than frontend, troubles?
Old 05-28-2002, 05:23 PM
lakeroadster's Avatar
lakeroadster lakeroadster is offline
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Post
Wider is better for handling, so that won't be a problem.
However, tire to fender clearance probably will be a problem.
How about trading your 9 inch for another that is the right width? I suggest posting here on this website what you need, width wise, and see if you can work out a swap.
Better to get the right parts now, than rework or replace parts later.
