rear width - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2007, 01:48 PM
rear width
Whats a good width for the rear end in a 1932 Ford Roadster or 3 window ? thanks
Old 01-09-2007, 01:55 PM
Asleep at the wheel....er, uh, differential.
Old 01-09-2007, 02:41 PM
WELCOME to Hotrodders.com
As a long time 32 Ford owner ... I would say most 1932 Ford owners want a rear end that is 56 to 58 inches wide ... measured this way ...
If you want a 8 inch series Ford rear end ... the V8 Maverick is 56 inches and works great. I myself prefer the added strength of a 9 inch series Ford ... and a 57 to 59 Ford rear end is almost 58 inches wide. I have a late 60's Ford Bronco under my 32 Roadster ... it is almost 58 inches.
I have a 57 Ford rear end under my 32 3W ... it will be a full fendered car also ...
Again ... WELCOME ...
Deuce Moderator ...
Old 01-09-2007, 05:42 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Hey Deuce.
I always heard that the V8 Maverick 8" is 56 inch and the 70's Granada 57 1/2. I have only measured 2 Mavericks 8" in the yards and they were both 57 1/2...... (maybe they had been changed?)...... same width as in my 63 Fairlane. Wish I could find a 56 inch. I could use the tire clearance. (I know the spring perches are unique center to center distance on the 62-65 Fairlanes.)
Should I search out another Maverick?
Old 01-09-2007, 05:50 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Check out this link:
http://50chevy.freeservers.com/Suspe...tml#Suspension
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 01-09-2007, 06:02 PM
xntrik's Avatar
Originally Posted by home brew
I'll tell you what. I am NOT any expert. But I have measured enough rear ends to tell you that there are lots of errors and generalizations on those charts. I wouldn't bet any money on much of anything on them..
Old 01-09-2007, 06:15 PM
I have friends who have the Maverick rear end under Model A's ... and they do measure 56 inches. These were out of the car ... measured with a tape measure ... the way I show in the photo above.
Now we all know that when dealing with used cars that are over 30 years old ... anything can be found. I know a guy who swears his V8 Maverick came with a 9 inch Ford ... but I believe it is really a 57 Ford unit ... with a WAR center section ...
Deuce ...
Old 01-09-2007, 06:54 PM
xntrik's Avatar
Thanks, my friend.
Here's one I have never answered.
How wide is the MII 8 inch and what is the perch dimensions?
Old 01-19-2007, 10:38 AM
A good rearend for a 32 is also: 66-77 Ford Bronco
I believe the 8 inch off the MII is the narrowest of them all. I'm pretty sure its 56". Although its only four lugs.
Old 01-20-2007, 11:58 PM
xntrik's Avatar
I've heard the early Bronco 9" was 56. What say ye Deuce?
Old 01-21-2007, 01:45 AM
powerrodsmike's Avatar
Wiki Edits: 161
I thought a drawback to using the early Bronco was the 5 on 5.5 bolt pattern.
And another internet chart....
http://dfwmotorsport.com/Fairlane/9inchrearends.htm
And yes, I find discrepancies in the charts also.
Mikey
BE different....ACT normal.
Old 01-21-2007, 03:24 PM
xntrik's Avatar
Mikey
LOL
Ya, and the springs are on the wrong side too......
Guess it can never be made to work.
Old 01-22-2007, 10:06 PM
Deuce Moderator ...
Did you use the 57 rear end as is ? Will the pumpkin be offset to the left? Or does it matter?
Old 01-27-2007, 08:21 PM
Rear Width
Picked up a 9 inch out of a Ford Granada, its around 52.250 flange to flange. It has the small bearing flanges (2.83 O.D.) will all the small bearing backing plates interchange , 9 inch and 8 inch , do they all have the same axle offset ?
Old 01-27-2007, 08:29 PM
car builder
I would check out the 8 inch ford.
They work great under the older cars.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 07:09 PM
s10 rear width 85 regal Transmission - Rearend 3 11-14-2005 02:24 AM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 09:14 AM
What is the rear end width of a 81' Chevy Half ton BillyBob1950 Transmission - Rearend 2 04-02-2003 05:29 AM
