rear window for 37 wild rod hard top convertible - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2010, 11:28 AM
i have the wrong glass for the rear window on my wild rod cabriolet with the lift off top. they are no longer in business anyone got any ideas or no where i might find one? the window has a slight curve to it.
Old 04-23-2010, 08:09 PM
I also have a WILDROD that sounds like yours. I have been told that you can use flat glass that you can have cut locally. You might contact 39FORD.COM I guess they are still in business they might be of help. I am going to see if I can't get one of the local glass shops to cut me one. I have been told the back glass did't have to be curved. The windshield and side glass does.
good luck OLDROD
Old 04-24-2010, 11:29 PM
406 bug's Avatar
9.82 @ 139mph
Use Lexan/plexigls. It can be bent and its easy to cut. Your local sign company can do the bending or maybe you can try dunking in boiling water to bend (not sure of this method)
Old 05-02-2010, 01:17 PM
HI SEFCOVIC
OLDROD here as I have not been on in a day or three or more I was wondering if you found a glass for your WILDROD?
OLDROD
any help ya'l luvchevs Body - Exterior 6 01-06-2010 10:35 PM
alligning impala doors sooper Body - Exterior 34 01-05-2010 05:16 PM
4 door hard top to convertible?? leamichael Body - Exterior 2 05-28-2002 08:51 PM
going convertible from a 4 dr hard top leamichael Body - Exterior 0 05-14-2002 07:50 PM
