rear window defrost - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2004, 08:04 AM
fast neutron's Avatar
New Member
rear window defrost
Hi. The wire on the rear window defogger has broken off on my broythers '94 mustang. Looks like they glued it on at the factory. Does anyone know what to use to put this thing back on? I need some kind of conductive glue.
Thanks.
Motorcycles are'nt dangerous. Soccer moms in minivans are!
Old 11-11-2004, 08:13 PM
Old enough to know better
I've seen a lot of those that were soldered on. If it looks like solder, get the glass pretty warm with a light or hot air gun from the outside and solder it back in place. You probably won't need any more solder, just heat the joint.
