Rear Window Install Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2005, 11:13 PM
I have a 1949 Chevy Styleline that I am putting the old rear window in with new rubber. I bought my rubber from National Chevy and it is the same rubber I installed 10 years ago. I am having a problem while putting the rubber on the glass. I can get it around most of the window and in most of the glass slot, but it seems like it is too small, almost like it needs to be stretched. I hesistate because I hate to force any pressure on that old glass.
Should I heat the gasket or something? I am alsmost thinking of using the old gasket as it is about 10 years old and still flexible. Any ideas. I do not rememebr it being this tough before, but hey, I was 10 years younger too. Thanks in advance for the help.
Ron
Old 10-23-2005, 11:23 PM
Put the rubber in a bucket of hot water for five or ten minutes, it will make a world of difference.
power rear window on a truck? jackflash Body - Exterior 1 04-28-2005 05:12 PM
8 1/4 to 8 3/4 rear end Leaf Spring Problem... 71gtx Transmission - Rearend 21 04-19-2004 08:17 AM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 07:38 PM
53 ford f100 rear window tgregoire Body - Exterior 1 07-16-2002 07:20 PM
40 Ford Tudor rear window regulators Tooch Body - Exterior 1 03-12-2002 11:30 AM
