Rear Window patch panel replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2011, 09:34 AM
67Elcamino's Avatar
Im planning on replacing the rear lower window channel panel on my 67 Elco and was wondering when doing so how I replace the studs where the molding clips will go into. The patch panel replacement doesnt seem to have these studs. Any recommendations?
[IMG][/IMG]
Old 06-03-2011, 09:50 AM
The studs for the reveal clips have to be welded on.Most use a stud gun type welder with collets or a tig will work.If you don't have either you can take it to a body shop before you weld in your patch panel.
Old 06-03-2011, 02:28 PM
put up or shut up
Most stud guns come with clips for those and the tip for it
Old 06-03-2011, 04:37 PM
Old Fool's Avatar
or you could use a small screw instead of the stud pin.
Patch Panel bobstoll Hotrodding Basics 3 08-25-2009 02:38 PM
79 TA, rear window seal replacement Gladis Body - Exterior 4 12-04-2007 04:56 PM
rear quarter patch panel dboyett Body - Exterior 4 11-01-2006 07:44 PM
67 Rear panel replacement Stangman196700 Body - Exterior 1 12-12-2005 07:28 AM
Patch panel replacement on frame or rotisserie? GMW Body - Exterior 2 10-08-2003 06:15 PM
