I'm using a hyundai rear wiper motor for another car. What I need to know is how to wire it up. I believe it is off of an 87 hatch back. There is a red, green,blue, and black wires. Also it has what appears to be a small capacitor on two of the wires. The red and green will make it work but I can't figure out how to get it to stop in its normal position instead of where-ever I shut it off at.I've tried several combinations but no luck.I have two motors and they both do the same thing so I don't think they're bad. Any help would be greatly appreciated.Thanks
Part of my job at work is to install the wiper systems on Airstream motor homes. We use Trico wipers but I would guess they would work similar to your wipers. The capacitors if they are square in shape are relays. They could go bad causing some of your problem. Also if the wiper arm is not installed correctly will cause them to stop in the wrong position. Four wire plugs like yours are for gas and five wire we use for diesels. I'm not sure how the wires hook up since all our stuff is premade for our application but will see if I can find a wiring diagram at work monday for you.
Paco is right, could be in your switch,too.
My thought which side is your switch on? On some of the aftermaket wipers for rods the switch is on the gound side. If it is wired up on the Hot side it is just like turning your key of on late model cars. They Stop at that point. Find a wiring diagram for it by checking out a mamual at your local auto parts store. Most of them have a wiring diag. in the back. Hope this helps just my thought.
Couldn't find a 4 wire diagram at work, just a five wire. Hilbilly is right too. One wire is hot/positive, one would be hi/fast one would be low/slow, one is ground. Can't help you with the color code. Sorry. Wish I could have done better for you.
I have found that Haynes manuals have wiring schematics towards the back of the book.also autozone sells these manuals. if you know the yrs and models of the donor cars and have a repore with your local autozone the may allow you to investigate your color code without having to purchase the manual. good luck
[quote]Originally posted by john:
<strong>I'm using a hyundai rear wiper motor for another car. What I need to know is how to wire it up. I believe it is off of an 87 hatch back. There is a red, green,blue, and black wires. Also it has what appears to be a small capacitor on two of the wires. The red and green will make it work but I can't figure out how to get it to stop in its normal position instead of where-ever I shut it off at.I've tried several combinations but no luck.I have two motors and they both do the same thing so I don't think they're bad. Any help would be greatly appreciated.Thanks</strong><hr></blockquote> seems awful simple ,but what about going to the hyundi dealer ,and check their shop manual ,talk to the eletrical tech ?..just a thought .. jim p .. |
