rearend for a 1932 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2013, 09:40 PM
what kind of rearend should i put in my 32 ford, would a ford explore rearend fit?
Old 03-13-2013, 11:46 PM
BOBCRMAN@aol.com's Avatar
Probably not. I would go for an eighties two wheel drive S-10.
Old 03-14-2013, 06:56 AM
big gear head's Avatar
High Performance Rear Ends
The Explorer rear end has a lot of pinion offset. You would need to shorten one side to center the pinion better. I like the smooth look of the 9 inch Ford and the 8 3/4 Mopar. They just look cleaner from the back. The quick change rear ends have a race look to them. You may need to narrow just about any rear end that you choose except the S10 rear end, which isn't very strong and doesn't have a very good look to it in my opinion.
Old 03-14-2013, 09:30 AM
DERPR30's Avatar
rear
an 8.8 from explorer 91- will fit just fine after a few mods thay go for around $100 at local junk yards
1932 ford 3 window Stretch1 General Rodding Tech 32 09-24-2015 07:21 PM
1932 ford 5 window droddy Body - Exterior 4 03-23-2010 04:10 PM
1932 ford rearend saturn2008 Transmission - Rearend 3 09-25-2008 11:52 PM
1932 Ford rims Kelsey Hayes or Ford motor Co. alf51chevy Suspension - Brakes - Steering 2 09-12-2005 09:14 PM
Ford 1932 project - what to do ? ManxCommando General Rodding Tech 7 10-19-2004 02:04 PM
