Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rearend for a 1956 F100
Old 09-10-2008, 06:48 PM
onebadmerc's Avatar
onebadmerc onebadmerc is offline
I need a bucket of arc sparks
Deuce, not trying to high jack the thread here, don't the 57-73 9" rearend out of trucks have 28 splines and the newer 73 and up trucks have a 31 spline axle. This brings me to another thing, I know the two wheel drive 73-79 trucks had a wider frame and a wider rearend. I have also heard that if you want a 31 splined 9" rearend in a pre 73 truck to use a 1973-79, F100-150, 4x4, 9" rearend. I read somewhere that the 73-79 F100-150 4x4 trucks used a 67-72 frame under them, have you heard anything about this?
