Rearend for a 1956 F100 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2008, 10:11 PM
Last journal entry: Day1 my attempt to build my own 56 F100
I was hoping to get some advice on whether or not the rear diff on a 1996 Pontiac Formula will work on my 1956 F100? I took the engine an LT1-350 and the transmission a 4L60, Just trying to match everything up.
Old 09-08-2008, 11:52 PM
techinspector1's Avatar
Wiki Edits: 326
I think it's an excellent idea to use everything from one donor. If the track is too wide, I think I'd cut the fenders and put a splice in them.
Old 09-09-2008, 12:12 AM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
The ford truck 9" is a bolt in from 57-73 into your 56.
What bolt pattern does your front suspension have? I would try to match that is possible.
Old 09-09-2008, 11:01 AM
It has a Mustang II IFS from Total Cost Involved. I think it is 5x 4 1/2.
Do you think it is possible to cut the rear diff to fit?
Old 09-09-2008, 11:34 AM
The 57 to 72 F-100 rear end is a bolt in ... no cutting or having to narrow it. It is a way better rear end than the 1996 Formula rear end. The only reason I could see for using the Formula rear end is ... IF ... it is a disc brake equipped rear end.
The 9 inch Ford is a lot stronger and a lot easier to work on. I would just install the Ford rear end and then buy a center section with a gear ratio very close to what the Formula has ... if I wanted that gear ratio. A lot of the Formulas had a 3.42 gear ratio. Ford has a 3.50
The Formula rear has a lot of stuff that would have to be cut off ... new axle pads welded on ... and I believe they are too wide.
A 57 to 72 F-100 rear end is just over 61 inches wide ... measured this way
A mid 70's Firebird/Camaro rear end is about 2 inches wider than the 57-72 F-100 rear so I know the 96 is too wide.
Moser Engineering can shorten your housing ( $110 ) and shorten axles. Same price But not all axles can be shortened ...
Moser has a web site ... below
http://www.moserengineering.com/Page...pservices.html
Old 09-09-2008, 12:10 PM
Excellent! Now I'm getting somewhere. My next question was the ratio, I'm trying to get past the headache of trying to match the rear diff to the transmission. The truck has the old original differential, so what you are saying is to just update the internal guts (gearing) to 3.42 or 3.5 ratio? Maybe just sand blast it powdercoat and away we go?
Old 09-09-2008, 12:44 PM
The 56 F-100 does not have the same gears and interchangeability of the 57 up rear ends ... so the original 56 F-100 rear end is not as user friendly. I would select a 9 inch Ford rear end ... from this donor list ... with the width you want ...
http://carnut.com/specs/rear.html
A rear end from a Ford passenger car would have the same wheel bolt pattern as your front end has now ( with the 5 on 4.5 pattern ) ... and use a ratio that is very close to the ratio in the Formula rear end. Do you know the ratio in the Formula rear end ??
Old 09-09-2008, 04:06 PM
I've been looking around on the Internet for the ratio of the 96 Formula but seem to find it...can you help me out?
Old 09-09-2008, 05:11 PM
Most GM rear ends have a tag on them that says what ratio they are. Also ... if you still have the donor Formula ...
This plate can tell what the ratio is ...
Old 09-10-2008, 03:20 PM
I went to the local Pontiac dealership and they informed me that my 1996 Formula donor had a 3.23 ratio rearend. It had an option for a 3.73. My question now is, what is the difference in performance from the 3.23 to the 3.73?
Anybody???
Old 09-10-2008, 05:48 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Deuce, not trying to high jack the thread here, don't the 57-73 9" rearend out of trucks have 28 splines and the newer 73 and up trucks have a 31 spline axle. This brings me to another thing, I know the two wheel drive 73-79 trucks had a wider frame and a wider rearend. I have also heard that if you want a 31 splined 9" rearend in a pre 73 truck to use a 1973-79, F100-150, 4x4, 9" rearend. I read somewhere that the 73-79 F100-150 4x4 trucks used a 67-72 frame under them, have you heard anything about this?
Old 09-10-2008, 09:59 PM
I'm hoping to get pushed in the right direction. I'm really confused and thinking that I'll just spend the $3000 that Currie Enterprises quoted me for a ready to bolt on rearend. Unless somebody else has any ideas.
Old 09-10-2008, 10:09 PM
Brian_B's Avatar
Lost in the 50s!
Posts #3 and #7 suggested the ford 9" which is bolt in and plentiful. You can swap the pumpkin to just about any gear ratio you want.
I have seen them go for as little as $150.
I have one for mine (traded some junk chevy parts for it)...if I ever get around to going and picking it up.
If you prefer the bolt pattern to match your front clip...a local machine shop can re-drill the shafts.
Old 09-11-2008, 06:45 PM
When you say pumpkin you mean the internal gears?
Old 09-11-2008, 06:47 PM
Brian_B's Avatar
Lost in the 50s!
Sorry. I meant the removable center section. Take a look on ebay for them and you will see what I mean. The last time I looked there were several center sections being sold with different gear ratios for the 9".
1956 Ford F100 Radio djboen General Rodding Tech 11 09-12-2013 10:41 PM
What volare IFS is best for 1956 f100? flyinv55 Suspension - Brakes - Steering 8 04-18-2008 01:23 PM
ford rearend installed in 1956 chevy car???? jmoon2 Transmission - Rearend 2 08-11-2006 10:05 AM
1956 ford F100 Vince Pacella Hotrodding Basics 6 02-05-2006 12:56 PM
53 F100 rearend What do i need? 53F100 Transmission - Rearend 7 01-24-2003 04:29 AM
