rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2013, 08:37 AM
rearend
Is the 8.5 10 bolt strong enough and worth narrowing?I will be using it a 71 nova with a 5 speed trans and a 454 BB approx 550 Hp.
Old 01-22-2013, 10:18 AM
big gear head's Avatar
High Performance Rear Ends
If you upgrade it with a 30 spline Eaton Posi, 30 spline Moser axles and set the gears up with the correct contact pattern and bearing preload it shold be fine. If traction is good then you might want to weld the axle tubes. How to weld axle tubes on GM 8.5" 10-bolt - NastyZ28.com This is the correct way to weld the tubes. Welding them with a MIG with steel wire will not work.
I've built several 8.5 rear ends like this and they have held up behind some 500+ cubic inch big blocks and are still working today.
95 YJ rearend Kims95YJ Transmission - Rearend 2 01-24-2009 10:53 AM
Need Rearend Help HARDEIGHT Transmission - Rearend 13 06-27-2006 10:16 AM
rearend G-mac Transmission - Rearend 2 04-02-2006 11:46 AM
new rearend ? Velyx21 Transmission - Rearend 3 05-26-2005 04:39 AM
Look at my rearend! Weimer Hotrodders' Lounge 14 09-17-2003 12:58 AM
