rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2006, 07:35 AM
rearend
Can I look at the rearend of my mustang and tell what size gear it is just by looking at it? It is hard to see any #'s on it because of the deposits and things from under the car.
Old 03-22-2006, 07:39 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
There should be an identification tag on a cover (or third member) bolt and will have this information on it, if you have it let us know the information on it.
If not, it will be a little harder.
Old 04-02-2006, 11:46 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You can jack it up and count the driveshaft turns for one turn of both rear wheels.
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 10:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
Looking for suggestion of rearend Shefron Transmission - Rearend 0 03-23-2003 11:23 PM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 08:04 PM
