Rearend advice? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2012, 10:43 AM
Rearend advice?
Nice title right...I have a 71 c10 weekend cruiser no dragstrip with what I assume is a stock rear end (open diff) with 3.08 gears? I am going to swap the sbc for a bbc and I don't know what to do with the rear end will it hold up and do I need/want to go with a posi or limited slip or any other options?..Any advice or suggestions...Thanks
Old 03-12-2012, 11:15 AM
SSedan64's Avatar
The stock 12-Bolt is plenty strong for a cruiser.
The Posi is your choice, it's not a necessity unless traction is a major need, towing, drag etc.... or you don't like the 1 wheel peel.
Old 03-12-2012, 02:42 PM
Should I buy new,used,junkyard?
Old 03-14-2012, 03:54 PM
SSedan64's Avatar
You may luck out & find a good used one. I'd check it or have it checked for Clutch wear before buying tho'. Probably best to buy new.
Stay away from the Gov Lock Carriers, their Ok for mild use, no burn outs etc.. they tend to break parts when going from dirt to pavement while spinning etc..
An Eaton Posi, Eaton/Detroit TrueTrac or Yukon Dura Grip would work well.
Auburn Posi Carriers aren't rebuildable, they use metal cones inplace of Clutch Plates like the Eaton & Yukon DuraGrip "Eaton Copy" use.
Carriers types, ID Pics >> http://rides.webshots.com/album/55410292AnMJrE
Courtesy of "BigGearHead"
Advice on buying new rearend... 83elky Transmission - Rearend 10 03-15-2008 08:09 AM
3rd gen camaro rearend advice 2wld4u Transmission - Rearend 2 06-19-2006 12:35 PM
Rearend Identification and Advice... JAHamilton Transmission - Rearend 11 10-01-2005 05:15 PM
Advice on rearend rebuild Vista Cruiser Transmission - Rearend 5 10-12-2004 09:43 AM
Need Rearend Painting Advice PrimaDude Body - Exterior 9 04-22-2003 04:20 PM
