which rearend fits 1950 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2010, 06:05 PM
streetrodderbn's Avatar
Certifiable Streetrodder
Customer is bringing a 1950 chevy 1/2 ton p/u I see chassis engineering lists a rear suspension kit, but recommends no specific rearend. What fits? Need to stick with 5 lug chevy bolt pattern 4 3/4".
Old 03-31-2010, 06:17 PM
55-65 will work just fine. You may have to relocate the spring perches on the housing to get the correct fit with the CE frame and springs as well as to get the proper pinion angle. If you want to go wider, mid 80s Monte Carlos, Camaros, or Firebirds would work fine.
Trees
Old 03-31-2010, 07:03 PM
big gear head's Avatar
High Performance Rear Ends
The first gen Camaro and '68 to '79 Nova rear ends are 60 inches wide. I have seen several of these rear ends installed in the '40s and '50s trucks. The 8.2 10 bolt from these cars is very cheap and there are many after market parts for them. The 8.5 from the '72and later Nova is stronger and also has many after market parts.
Old 03-31-2010, 08:24 PM
Wiki Edits: 31
wouldn't an S10 4x4 rear end work? there 60" wide and probably a bit easier to find than early Camaro/Nova rear ends... 8.5 rears came standard on most V6 models '99 up so it wouldn't be that hard to find 1
Old 04-01-2010, 08:35 AM
The 8.5 from a ZR2 would be fine, but I wouldn't use the 7.5 10 bolt. The S truck rear ends have smaller axle tubes. They are about 2 5/8 instead of the normal 3 inches. The S truck 8.5 will have 30 spline axles.
Old 04-01-2010, 08:58 AM
Wiki Edits: 49
Any mid '70s Camaro or Firebird will work just fine. Here's my '53 before I sold it. It had a 78 Firebird 10 bolt posi unit I picked up at a swap meet for a hundred bucks. Also had stock '69 Camaro rally wheels and trim rings.
Centerline
HotRodsAndHemis.com
The most important things you learn are those things you learn AFTER you know it all. -- Chip Foose
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
1950 Chevy Truck DC50Chev Introduce Yourself 2 09-01-2007 07:58 PM
Camaro rearend in "55 Chevy truck BillCull Transmission - Rearend 11 02-09-2007 08:19 PM
Camaro Rearend in '55 Chevy Truck BillCull Hotrodders Site Suggestions and Help 3 02-01-2007 05:33 PM
ChopTop 1950 Chevy Truck efland07 Body - Exterior 4 11-28-2005 08:47 PM
