Rearend and front spindle - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2005, 01:12 PM
I have a rearend and front spindles from what I was told were from a Lincoln Versi, I dont know the year, so I would like to know how to fined the year and would the front spindles fit to a Pinto IFS suspension?
Old 09-18-2005, 04:03 PM
The rear end should have disc brakes and the fronts should be also.
They should be the common 5 on 4.5 wheel pattern. Some Bigger Lincolns had the disc too but the heel pattern is larger also.
Old 09-19-2005, 07:36 AM
Deuce
Thanks for the info. Yes they do come with disk braks front and back, Im planing to istall this puppy on my 1929 pickup truck, also would you know if the front spindles would bolt on to a pinto IFS front end Im not sure on the year of the pinto? Thanks again hope to hear from you soon.
Old 09-19-2005, 09:50 AM
ckucia's Avatar
You may already know this, and I may be wrong, but isn't the Lincoln Versi essentially a Granada?
Old 09-21-2005, 08:15 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Yep it is, but the Versailles has bigger ball joint studs than its siblings. Nope the spindles don't work well on MII geometry.
Old 09-22-2005, 07:24 AM
Thanks for the info. we'll keep in touch.
what year front rearend assys will fit huffed6 Transmission - Rearend 2 03-22-2005 08:43 AM
Rearend Angle morenbd Transmission - Rearend 8 03-28-2004 07:11 AM
Question about noise in just rebuilt rearend???? Robbie Transmission - Rearend 0 02-05-2004 08:20 AM
Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps Jon Suspension - Brakes - Steering 0 10-12-2003 03:56 PM
51 Chevy front end Jamie Suspension - Brakes - Steering 2 11-21-2002 06:50 AM
