rearend gear change affect on ET? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2008, 08:34 PM
how much (ball park figure) will going to a 4-10 gear from 3-55 lower my e.t.
i have a '67 belvy deuce, 383 built a little, .030 over, balanced, flat top pistons, .474 lift, .280 duration, 2500 stall, he can run low 14s with the 3-55.
Old 12-01-2008, 11:43 AM
Wiki Edits: 49
What in the blazes is a Belvedeuce??? The only real DEUCE is a 32 Ford.
Old 12-01-2008, 08:22 PM
belvydeuce
i have a '67 plymouth belvedere II silver special.
GM 7.5 in 1977 Oldmobile. Rear gear change cars4megames4u Transmission - Rearend 10 11-17-2008 09:16 PM
3.42 1st gear and 3.70 rearend retired 56 Transmission - Rearend 7 11-22-2007 11:56 PM
14" to 16" tires gear ratio change? pi71 Transmission - Rearend 3 10-16-2007 07:57 PM
What's it take to change my rearend to posi? batman09 Transmission - Rearend 1 12-03-2004 05:36 PM
hi, i have a rearend gear question Thuggishruggish3000 Transmission - Rearend 2 08-10-2003 12:55 PM
