Rearend Gear Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2012, 09:44 AM
alrobjr's Avatar
Big Al
I am ordering the Eaton Posi from Tom's Differential for my GM 7.5 10 Bolt 26 spline rearend which is a 2 series carrier. The Eaton is 3.23 up and I will be installing 3.42 gears , but shall I order the standard or thick gears ?
Old 08-13-2012, 11:01 AM
prostreet6t9's Avatar
Differential/Driveline
You do NOT need thick gears.Just order a normal gear set.
Old 08-13-2012, 11:05 AM
big gear head's Avatar
High Performance Rear Ends
The thick gears are for the 2 series differential and the standard gears are for the 3 series. The new Eaton Posi will be a 3 series. Be sure to get a good installation kit from Tom while you are ordering parts.
This would be a good time to upgrade to 28 spline axles. Chances are that your axles are worn and need to be replaced anyway, and the 28 spline axles will increase the strength of the rear end. The 7.5 was upgraded to 28 spline in '90, so '90 to '92 axles will fit with a 28 spline Eaton Posi.
Old 08-13-2012, 11:57 AM
alrobjr's Avatar
Big Al
Thanks Big Gear Head for your advice , I am ordering the installation kit along with the aluminum rearend cover because he has reasonable prices . What can I get the 28 spline axles from friend ?
Old 08-13-2012, 12:16 PM
'90 to '92 Camaro or Firebird. Tom also has them. Tom sells AAM axles, which are very good quality.
gear ratio rearend myownharley11anthony Engine 0 08-14-2010 09:06 PM
rearend gear swap mjascur Transmission - Rearend 21 03-15-2010 09:24 AM
what rearend gear ratio do i have? ferociousd Transmission - Rearend 4 07-16-2007 05:40 PM
Which rearend gear should I use? the ernster Transmission - Rearend 4 12-27-2006 10:33 AM
hi, i have a rearend gear question Thuggishruggish3000 Transmission - Rearend 2 08-10-2003 01:55 PM
