rearend help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2006, 07:22 PM
rearend help
I wondered if any of the xperts might know what ford trucks ie. ranger, bronco or one of the later model cars have a 56" rearend. Iwill be using coil-overs so I will have to weld some anyway. I am working on a 37 ford roaster and have been told to use a 56" rear and front.
thanks 39 OLDROD
Old 01-11-2006, 07:30 PM
A V8 Maverick ( with 5 lug wheels ) is 56 inches wide.
measured THIS WAY......
I actually prefer a 58 inch wide rear.....under a 35 to 40 Ford. 1957 to 1959 Ford cars are that width and are of the vastly popular 9 inch Ford series.
Here is a site with some rear end widths listed......
http://www.quickperformance.com/Tech...us_measure.htm
Old 01-11-2006, 07:56 PM
rearend help
Thanks I have looked at the site and don't see any thing but old stuff that is hard to find I did not see any thing on the ford ranger or any of the things that are so plentyfull. Don't need to spend a grand when some of the rear ends in the junk yard will work just fine I just thought some of you fellowers had been that route. I done got to old laY on the grown to use a tape on the cold wet grown but thanks .
OLDROD
Old 01-11-2006, 10:59 PM
In my part of SC.....57 to 59 Ford rears bring $150 to $200 all day long.
Rangers do not have the gear ratios readily available that 9 inch Fords do. IF you are determined to put a late model Ford under the 37 roadster.....look at a Explorer.....most of the later ones have factory disc brakes.....with a parking brake...
QUESTION ....
The 37 roadster.......is it a original Ford 37 roadster or something else ?
Old 01-12-2006, 01:13 PM
Thanks thats what i had in mind do you know how wide they are Oh ya i can get one with disk for $125 with drums $100
thanks OLDROD
Old 01-12-2006, 01:16 PM
Oh yes it is a glass car
later OLDROD
Old 01-13-2006, 12:39 PM
New Member
Rangers and explorers use 7.5" rears. They don't handle very much torque. They are designed for a 4 or 6 cyl. If you are running a decent V8, and want a late model rear, look for a GT Mustang. It has an 8.8" rear that will handle a V8 and you can find wrecks from the 80's for a few hundred bucks for the whole car. However, I don't know what the width is. You can probably find out at the junk yard. They should have at least one out of the car that you can drag a tape measure across. If not, one of the yard hands will probably measure it for you.
Old 01-13-2006, 01:33 PM
rearend help
Thanks Caveman do you know what a full size bronco has no need to ask the ford place. I don't know if they had disk brakes on any of them or not I can get a early mustang 4 bolt for $100 but I did not need to spend the bucks for the conversion.
thanks OLDROD
Old 01-14-2006, 03:06 PM
New Member
A full size Bronco rear is the same as a full size pickup, so that's probably not what you're looking for either. It's too wide and has a 5.5" bolt pattern. If you can't find any of the cars whose rears are listed on the website mentioned above, you might consider something from Chrysler. The mid-size cars of the 80's had 5-lug Dana rears with 4.5" bolt pattern. I don't know if the width is perfect for your application but you can find out at the junk yard.
Old 01-14-2006, 06:02 PM
[QUOTE=Deuce]A V8 Maverick ( with 5 lug wheels ) is 56 inches wide.
I have a small bronco 9in and I believe it is 58" from wheel mount flange to wheel mount flange. Ed ke6bnl
Old 01-17-2006, 08:07 PM
Rearend
Thanks fellows i think i have one that will work if the man did not fib to me i'll know for sure wednesday is is a Granada
later OLDROD
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 11:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 09:04 PM
Ford Rearend 00stang Transmission - Rearend 5 08-25-2002 05:12 AM
