rearend ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2010, 02:04 AM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
rearend ID
I have a Camera rearend in my 1948 Chevrolet Fleetline project but I do not know the year nor the ratio. The housing does not have a metal id tag. How can I learn what I have?
Old 10-06-2010, 03:04 AM
fast68's Avatar
likes chevy trucks & boobies
bottom of the diff housing under the diff cover have two little fangs at 5 and 7 o clock positions, or are they square corner shaped ?
if small fangs then its a 7.5 or 7.625
if square 90 degree then its a 8.5
the F body 8.5 were originally leaf, and were through 1981
and the smaller F body rears were originally coil with panhard and torque arm from tranny tail along driveshaft, 1982 up
also if it has a 9 bolt diff cover then its a borg warner 1988 and similar years F body, 3.27 most common ration in these and most were LSD equipped
do a google pics search for GM 8.5, 7.5 and borg warner 9 bolt
i assume you mean camaro anyways...
Old 10-06-2010, 09:13 AM
big gear head's Avatar
High Performance Rear Ends
You mean a Camaro rear end? There is a number stramped into the right axle tube on the front side that will identify the rear end. It might be hard to find. It might be covered with dirt or rust, but it should be there.
Need suggestions on 9" Ford Rearend Narrowing S10 Racer Transmission - Rearend 8 01-21-2010 01:56 AM
Welding Rearend 23 T General Rodding Tech 26 04-21-2008 07:49 PM
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 11:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 09:04 PM
