Rearend ID help... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2007, 10:57 AM
Rearend ID help...
What is the easiest way to identify if I have an 8.2 or 8.5 rear end? My cover is the one with the buldge in the middle going from top to bottom. This should mean an 8.5 however, it is a 71 Malibu which had a 307 and I don't think they put 8.5's until 72. Can't see any numbers on the housing. If I take the cover off, what do I measure or look for? Thanks!
Old 06-15-2007, 01:21 PM
GM went to a corporate 10 bolt in '71 didn't know that until today.
Old 06-15-2007, 01:22 PM
ooops, it was an 8.5
Old 06-17-2007, 09:27 PM
http://www.oldsmobility.com/10bolt-tech.htm has pics
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 11:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
57 chevy REAREND dillema AND1TOO Transmission - Rearend 1 05-04-2003 12:16 AM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 09:04 PM
