I have a '53 Chevy p/u that I have purchased a TCI Mustang II IFS front and four bar rear airbag suspension for, and am planning on ordering a Currie 9" rearend. Currie's website explains what measurements need to be provided when ordering, but I need to know exactly how to arrive at these measurements. I suspect I need to have my wheels and tires on hand in order to get these measurements (?), and I don't want to order a rearend more than once! Any advice anyone can give me would be greatly appreciated. Thanks in advance.
Stinkin_V8,
Got part of your message, but no link(?). Can you please re-post? |
Stinkin_V8,
Thanks for the info. This really helps, and reinforces what I was kinda' thinking. If I am reading you correctly, I should be able to obtain my wheels and tires (keeping in mind the bulge) that will fit inside my fenders, then take my measurements from there. Spacing from the frame should be kept at about 1" to 1-1/2" with the same from the fender? Thanks for the link too, it is one I have not seen before. |
I'm guessing if you need a Currie rear end, you've got enough juice to need some fairly big rubber in there. I don't know what the rule of thumb is for clearance. I should have between 3/4-1" clearance on my inner fender wells with the additional spacers I mentioned. Maybe some of the other folks here could pipe up with their reccomendations.
I have no clearance problems on the outer fenders, but you'll want to watch the travel of the suspension. If your truck is real low, the rear axle may move enough to contact the inner fender above the wheel opening. Sounds like you've got it figured out - get the wheels, put 'em in the wheel wells and measure.
