Rearend Noise !!
I just finished rebuilding my 7.5" 10 bolt after trashing one axle and the auburn posi. I went back in with Moser 28 spline axles and a Detroit Truetrac diff.
I used the Moser axle bearings/seals, a complete Richmond install kit including new pinion and carrier bearings and Richmond Sportsman 3.73:1 gears. I had a pro shop set up the gears.
Even though the gears are a little noisier than I hoped, the problem is that I get a LOT more gear/bearing (?) noise when cornering to the right than to the left. I called Detroit and they said that the diff should be quiet under all circumstances.
The pro went back through the rear end and didn't find anything wrong except a very slight rub inside the right brake drum where the shoes rubbed. We filed the brake shoes slightly, but the noise is still there.
Any Ideas how to fix it???
