Rearend For Nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2003, 06:20 PM
New Member
Post Rearend For Nova
Will a rearend out of a 75 Firebird Formula fit in my 72 Nova. And what would be the gear ratio for the stock rearend in the formula.
Thanks <img src="confused.gif" border="0">
Old 05-27-2003, 02:03 AM
Post
The rear end housings are different lengths & the spring perches are not spaced the same, but the differential & gears will work. (assuming they are both 8.5")
Old 05-28-2003, 04:10 PM
New Member
Post
Would anyone know the gear ratio of the firebirds stock rearend.
Old 05-29-2003, 03:16 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Post
[quote]Originally posted by novachad:
<strong>Would anyone know the gear ratio of the firebirds stock rearend.</strong><hr></blockquote>
Anywhere from 2.41 to 3.42 depending on how it was ordered. With the 2.41 and the 3.42 the most common of all the available ratios. I've seen 'em both ways in otherwise identical cars. From what I can gather Novas went to the 8.5 in late '71 or '72. If yours isn't an 8.5 then a '73 up Nova housing would be a bolt in and would accept the Firebird carrier and gears.
[ May 29, 2003: Message edited by: Hippie ]</p>
