Rearend Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2008, 03:05 PM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
Rearend Question
I have a mud truck with a 350 In it with gag me 2:56 gears it doesnt throw much mud due to the gears. It also has a turbo 700r4 tranny. I have another older truck that I was told has faster gears.
What I was wondering is. How do I figure out the gears in the rearends in the truck and what would be a good gear to have for this application without having a 350hp motor.
thanks
Ed
Old 02-27-2008, 03:43 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Ed,
How do you know the truck has 2:56es in there?
How did you find that out?
There may be a tag attached to one of the bolts on the housing that will give ratio info, or a door plate w/axle ratio
if no info there, you'll need to jack it up & support it.
Put a chalk mark on the drive shaft & the tire (or use the v/stem) & turn the tire one revolution while counting how many times the drive shaft turns, 3 3/4 turns of shaft 1 wheel revaluation
3:73-1 shaft 4 & a little, wheel 1, 4:10-1
if the gears are where you can count the teeth, you divide the ring gear buy the pinion gear.
Take care,
Rich
PS The higher the gears numerically, the easier to spin the wheels
Old 02-27-2008, 04:56 PM
Holder350's Avatar
Auto Parts Professional
Just adding a bit to richards's post.....if the rear end is not a posi track unit only jack ONE wheel up, if it is a posi unit jack both wheels up
Old 02-28-2008, 10:55 AM
400smb_s10's Avatar
Back Yard Junky :)
A while ago I got help on here with the ring gear and pinion gear math thats how I got the 2:56 gear. I forgot how to do it and I couldnt find my post.
Thanks for the help its appreciated
Ed
Question About 9" Ford Rearend STATUTORY GRAPE Transmission - Rearend 6 07-30-2006 03:31 PM
68 Firebird rearend posi question smily1 Transmission - Rearend 2 09-30-2004 07:47 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
hi, i have a rearend gear question Thuggishruggish3000 Transmission - Rearend 2 08-10-2003 12:55 PM
